API entity.compute() receiving params but method sees None - parameter passing issue
I’m calling a view method in another workspace via entity.compute(), passing a dict with a temperature parameter at the top level. The dict arrives correctly (confirmed via debug logs), but inside the called method, params.get('temperature') returns None, causing the code to crash.
Setup:
  • Calling app (Heat Exchanger Designer): Uses API to call Food Properties workspace
  • Called app (Food Properties): Has a @TableView method that should receive temperature parameter
Code in calling app:
# Prepare params dict with temperature
params_dict = entity_params.toDict() # Convert Munch to dict
params_dict[‘temperature’] = 65.0 # Add temperature parameter
# Call remote entity method
result = entity.compute(
method_name="calculate_properties_for_heat_exchanger",
params=params_dict
Debugging shows the following:
DEBUG: Calling Food Properties API for sample 2 (Water (TEST)) at 65.0°C
DEBUG: Calling entity.compute with params keys = [‘foods’, ‘temperature’]
DEBUG: Full params_dict structure:
{ “fat_wt”: 0, “density”: 1000, “porosity”: 0, “food_name”: “Water (TEST)”, “dry_matter”: 0, “food_group”: “Other”, “protein_wt”: 0, “minerals_wt”: 0, “temperature”: 65.0, “specific_heat”: 4.18, “viscosity_files”: “<viktor.api_v1.FileResource object at 0x00000275BA1474D0>”, “carbohydrates_wt”: 0, “manual_viscosity”: 0.001, “heat_conductivity”: 0.5, “concentration_factor”: 1, “rheological_behavior”: “Newtonian”, “enable_viscosity_upload”: false, “food_composition_boolean”: true } ]
“temperature”: 65.0
DEBUG: Error in entity computation: Computation failed with an error (type: error_code, details: )
Code in called app (Food Properties controller):
@vkt.TableView("Properties for Heat Exchanger")
def calculate_properties_for_heat_exchanger(self, params, \*\*kwargs):
    """Display food properties formatted for heat exchanger calculations
    Can be called remotely via API with temperature parameter.
    \# Get temperature parameter (for API calls) - use attribute access for Munch objects
    temperature = getattr(params, 'temperature') or params.foods.food_samples\[0\].get('temperature')
    try:
        food_samples_params = params.foods.food_samples
        if not food_samples_params:
            return {"error": "No food samples defined"}
        \# Use the temperature parameter to calculate properties
        foods = \[Food(sample, temperature) for sample in food_samples_params\]
    except AttributeError:
        return {"error": "Please configure food samples first"}
// Existing code not relevant for this issue
    \# Build table data for heat exchanger
    table_rows = \[\]
    \# Properties relevant for heat exchanger design
    hex_props = \[
        ("Temperature (°C)", "temperature", 1, None),
        ("Density (kg/m³)", "total_concentration_kgm3", 1, None),
        ("Specific Heat (kJ/kg·K)", "specific_heat", 3, None),
        ("Thermal Conductivity (W/m·K)", "heat_conductivity", 4, None),
        ("Viscosity (mPa·s)", "viscosity", 3, "viscosity_special"),  # mPa·s with 3 decimals
        ("Concentration Factor", "concentration_factor", 2, None),
    for prop_name, prop_key, decimals, special_handling in hex_props:
        row = {"Property": prop_name}
        for i, food in enumerate(foods):
            sample_param = food_samples_params\[i\]
            try:
                if prop_key == "temperature":
                    \# Use the temperature parameter directly
                    row\[sample_names\[i\]\] = f"{temperature:.{decimals}f}"
    df = pd.DataFrame(table_rows)
    \# Create column headers
    column_headers = \[vkt.TableHeader("Property", align="left")\]
    for name in sample_names:
        column_headers.append(vkt.TableHeader(name, align="center"))
    return vkt.TableResult(df, column_headers=column_headers)
When entity.compute() passes a dict with params={'foods': {...}, 'temperature': 65.0}, what type does the receiving controller’s params argument become? How should I access the temperature key in the called method?
Should I use:
  • params.get('temperature') (dict method)
  • params.temperature (attribute access for Munch)
  • getattr(params, 'temperature', None) (safe attribute access)
What’s the proper way to pass and retrieve custom parameters via entity.compute() API?
I tried multiple ways with some help of Claude, but i keep running into the same issue that temperature keeps returning None.
Called with @MSEP, and this issue was solved. After some trying all is up and running and the difficulty was likely due to not matching the structure of a dynamic array (which is a list of dicts) in the params that were sent into the compute method.
