As a developer, I would like to access the activities via an API to evaluate and compare the data with other information.
No workaround.
No workaround.
@sonomirco thanks for suggesting this feature! Can you please elaborate on what the use case is exactly, and what stats you would like to retreive? This helps us determine what the best solution would be ![]()
If I want to create a dashboard report where I collect all the information regarding tools we are using, I need manually to add this information by looking at the Viktor dashboard.
So I could retrieve:
Thanks for sharing! I have added it to our internal issue tracker
Hi there,
I just now stumbled across this feature request again, @sonomirco, have you seen the audit feature on the activity tab in your environment?
I think most, if not all the data you’re looking for are now available there. Is there something that’s still missing or is this indeed the feature you were looking for?
The API documentation regarding activity data is now available online
