When I want to install viktor-cli I got the following error:
ModuleNotFoundError: No module named ‘pip’
Exiting because of an error: installation of the app failed
Does someone know how to fix this?
Hi Jip,
pip is the package manager of Python. It normally comes with your Python installation. Several questions to help pinpoint the problem:
viktor-cli check-system return without any problems?Regards,
Hi Raoul,
To answer your questions,
Jip
Hi Jip,
conda --version in your terminal .conda install pip
pip --versionpip3 --versionHi,
I tried that but than I got:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package python3-pip is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘python3-pip’ has no installation candidate
Jip
Hi Jip,
You said you are using windows, however is it possible you are using Windows Subsystem for Linux (WSL)? Because this tells you to install pip using sudo apt install python3-pip which is a Linux command, not a Windows command. WSL behaves as a Linux computer inside your Windows machine.
If that is the case, you can use that command to install pip. If you have never used WSL before, it is likely it will tell you that you have to update apt as well. You can do that with sudo apt update
regards,
Paulien
Hi Paulien,
Ah sorry, that is what I’m using. After using sudo apt update, I could use sudo apt instlal python3-pip. But then I tried to install vicktor-cli and got the same error as before.
Jip
Hi Jip, could it be installed as pip3 instead of pip. i.e. is pip3 --version still not recognised as well?
Hi Paulien,
If I try to install pip3 instead of pip, I got the following error:
But the pip and the pip3 --versions are recognised:
Jip
Hi Jip,
You said you use python3.9, but the pip versions you list seem linked to python3.8? Maybe that is where the problem is?
The problem was caused by the fact that a Windows version of the CLI was installed and executed, while a Linux version of the CLI is required when developing on WSL2.
