Add f-strings with output fields to Text fields
As a user, I want to be more flexable with showing output in my parametrization. I want to add them in my regular Text field (or other elements like tables), for instance with an f-string. This improves the readebility of my parametrization.
Hi @marliesbuijs ,
I believe this feature request is similar to this one:
As a developer I want to create an output field that looks more like the normal text in the user input side (as now the OutputField is limited to the greyed out interface and one line). This benefits more flexibility for the developer to create neat user interfaces for users with the flexibility they want.
I think this is relevant for the VIKTOR platform because it gives more flexibility.
Out…
Could you check if this is the case?
@mslootweg yes, you can delete this one then. I will put my input at the other ticket.
