A field filled by a callback function behaves differently once published
SDK: v14.11.0
Platform: v24.06.6
Python: v3.12.3
Isolation mode: venv
A field that was filled properly in the ā€˜Development’ workspace thanks to a callback function is now empty at all times once the app is published.
I should behave like it does when started in the ā€˜Development’ workspace with a terminal call to viktor-cli start.
I fill a field with IDs separated by a comma in a first Step :
(I used the same for both the Development workspace and the one for the published app and tried others input aswell).
This is what i get in the Development workspace :
And in the published version workspace :
Thanks for your attention.
Hi @SolalSPC ,
Could you share what the callback function does? From where does it retrieve the options?
Here’s the callback function :
def createFdesPepOptions(params,**kwargs):
  if database == {}:
      return []
  else:
      idlist = [x[0] for x in database.items()]
      fdes_pep_options = [OptionListElement(id, label = id + ' - ' + database[id]['Nom du produit'][0][:109]) for id in idlist]
      if fdes_pep_options == None :
          return []
      return fdes_pep_options
To give you some context, database is a json-formatted string that I declare as a global variable in app.py, it is then overwriten with data retrieved through an API when the user types in some IDs in a text field.
This callback function is used to display options on the next Step depending on the IDs given by users at the first Step.
Thanks in advance.
Maybe there’s a difference when calling the API? are you using an environment variable of some sorts to authenticate?
It’s very difficult to help you without a full example showing the problem. I cannot replicate the difference on callback behavior between development and production.
Yes, I understand, I’ll continue to investigate, I’ll post an update there when I fix the problem.
