I made GeoPolygon of neighborhoods in The Hague. I made parameters of rain. I want the Polygon to change color when it starts to rain harder. However, I am unable to get and use this parameter. Can someone help me with this.
This is my code:
trees = NumberField("Trees", default=10, min=10, max=10000, step=10, suffix="pieces", variant="slider")
green_roofs = NumberField("Green_roofs", default=10, min=10, max=10000, step=10, suffix="m2", variant="slider")
rain_barrels = NumberField("Rain_barrels", default=10, min=10, max=10000, step=10, suffix="pieces", variant="slider")
intensity = NumberField("Intensity", default=1, min=1, max=44, step=1, suffix="hours", variant="slider")
rain = NumberField("Rain", default=5, min=5, max=100, step=5, suffix="mm/h", variant="slider")
size = NumberField("Size", default=(100/44), min=(100/44), max=100, step=(100/44), suffix="%", variant="slider")
set_params_btn = SetParamsButton("Set params", "set_param_a", longpoll=True)
button = DownloadButton('Perform download', method='perform_download')
Rain2 = MultiSelectField('Rain2', options=['5', '10', '15', '20', '25', '30', '35', '40', '45', '50', '55', '60', '65', '70', '75', '80', '85', '90', '95', '100'], default=['5'])
if '5, 10, 15' in Parametrization.Rain2:
f = open('wijken.json')
data = json.load(f)
list_features = []
for i in range(len(data["features"])):
list_coordinates = []
for j in range(len(data["features"][i]["geometry"]["coordinates"][0])):
coordinates_rd = tuple(data["features"][i]["geometry"]["coordinates"][0][j])
lat, lon = RDWGSConverter.from_rd_to_wgs(coordinates_rd)
print(lat, lon)
list_coordinates.append(MapPoint(lat, lon))
list_features.append(MapPolygon(list_coordinates, color=Color(242, 246, 68)))
elif '20, 25, 30, 35' in Parametrization.Rain2:
data = json.load(f)
list_features = []
print(lat, lon)
list_features.append(MapPolygon(list_coordinates, color=Color(255, 154, 5)))
else:
data = json.load(f)
list_features = []
print(lat, lon)
list_features.append(MapPolygon(list_coordinates, color=Color(231, 29, 29)))
And this is my error:
TypeError: argument of type ‘MultiSelectField’ is not iterable
