Is it possible to visualize a rhino model (saved as model.obj file) in GeometryView without having to reconstruct it in Viktor? Just to call it from Rhino and preview it.
Hi @MonicaB
As far as I know, no, not directly. If you want to use the GeometryView
you have to supply a GeometryResult
, which takes a Group
of VIKTOR Geometry objects. So you would need to create a group of Geometry objects (extrusions, spheres, beams, etc.) from your model.obj file. While we donโt supply a from_obj
method in the SDK I donโt think it should be too difficult to write a from_obj_to_viktor_geometry
function, because the .obj file is open and the file structure is well documented, see for example https://www.cs.cmu.edu/~mbz/personal/graphics/obj.html It would depend on your specfic .obj file structure a bit how much work that would be.
As you can see in the Automate the boring, engineer the awesome section here, @mslootweg has made something partially similar for mayavi models.
We are currently working on supporting GLB files (glTF format in single binary file) in the GeometryView
, as this is the de-facto file format for 3D scenes and models. Likely Rhino also has the possibility to expert to glTF/GLB, or there are (Python) tools available to convert .obj to GLB.
More info to comeโฆ
