# Pycharm stubs not found
**URL:** <https://community.viktor.ai/t/pycharm-stubs-not-found/291>\
**Category:** Need help? Ask here!\
**Created:** [22 February 2022 13:59 UTC](https://community.viktor.ai/t/pycharm-stubs-not-found/291 "2022-02-22T13:59:53Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![rdejonge](https://community.viktor.ai/letter_avatar_proxy/v4/letter/r/ba8739/32.png) [@rdejonge](https://community.viktor.ai/u/rdejonge)\
**Post date:** [22 February 2022 14:38 UTC](https://community.viktor.ai/t/pycharm-stubs-not-found/291/2 "2022-02-22T14:38:14Z")
</div>
Hi Enrique,
Are you using a virtual environment as isolation mode? In that case the dependencies of the app are not installed in the viktor-installs folder, but inside the virtual environment. If you are using a virtual environment you can select the project interpreter from the virtual environment folder. After doing this, Pycharm should automatically recognize the installed dependencies that are present in the virtual environment. I will adjust the docs to reflect the correct set up when using a virtual environment.
What is the Python version you are currently using? I have the idea that Pycharm currently doesn’t correctly recognize Python 3.10, which also gives me import errors. When switching to a different Python version I do get correct code completion.
_[View the full topic](https://community.viktor.ai/t/pycharm-stubs-not-found/291)._
