Hello, i’m having trouble while trying to run the first app.
Until the installing part everything runs according to the tutorial, but when i try to start in the browser it gives me the 404 error, i already check the spelling and try to see if the firewall is blocking.
When running viktor-cli start
you should see your URL in the command-line shell (“Connection is established: https://…”). Depending on your shell, you can either click it, CTRL-click it, or just copy-paste in your favorite browser.
Notice that your command-line shell should still be running with the bottom message “App is ready”.
Thanks it worked, it was just that the url of the tutorial using the prefix “dev-…” isn’t the default for me it was just the clud.viktor.ai
