I want to place multiple points on the map in the Viktor app. The example at the site of Viktor is only using self typt coordinates.
(Results & visualizations - Map | VIKTOR Documentation)
Is it possible to use an array with multiple coordinates in it. So you can see all the points from the array on the map?
If I understand correctly, you can use Python to do this:
@MapView('Map view', duration_guess=1)
def get_map_view(self, params, **kwargs):
features = []
for x, y in my_array:
features.append(MapPoint(x, y))
return MapResult(features)
Or, for minimum code:
return MapResult([MapPoint(x, y) for x, y in my_array])
