Hi there,
I have a question regarding processing multiple uploaded Excel files.
Right now, I have made three separate FileFields where I can select the excels I’d like. I do not want to process them right away using @ParamsFromFile, but I would like to load them into a class containing dataframes later on, something like this in the controller:
def import_data_set(excel_1=None,
excel_2=None,
excel_3=None):
'''This function imports three Excel workbooks
returns a DataSet (internal class)'''
data = DataSet()
if excel_1 is not None:
data.df_1 = pd.read_excel(excel_1)
if excel_2 is not None:
data.df_2 = pd.read_excel(excel_2)
if excel_3 is not None:
data.df_3 = pd.read_excel(excel_3)
return data
However, I am stuck on how to read the files into dataframes. The below code does not work.
pd.read_excel(params.fileresource_1.file.source)
Does it have something to do with that the source type of the file is a URL type? Your help is much appreciated.
Thank you in advance,
Yida
