Getting error while publishing the app
Alright is there a reason for pinning it explicitly? Pathlib is part of the standard Python library, so it should not be necessary to add it as separate requirement. Currently this results in an import error, because pathlib is using an old import path:
Traceback (most recent call last):
  File "<string>", line 1, in <module>
  File "viktor_connector/connector.pyx", line 22, in init connector
  File "/builds/viktor-core/viktor-packer/site-packages/pathlib.py", line 10, in <module>
    from collections import Sequence
ImportError: cannot import name 'Sequence' from 'collections' (/usr/local/lib/python3.11/collections/__init__.py)
Could you remove pahtlib from the requirements file and try again?
