When a MultipleSelectField has options selected and the visibility is toggled False with a ToggleButton, the frontend will color the label of Section and Tab red. Is there a workaround for this?
Before untoggle:
After untoggle:
Before untoggle:
After untoggle:
The options are probably filled dynamically depending on the toggle?
You could do something along these lines:
def options(params, **kwargs):
if params.toggle:
options = [...] # api call to GEF files
return params.selected_gef_files # keep options which are currently selected
Thanks @khameeteman. This works, but i am not sure why yet
I was returning a list with one OptionListElement, with a default value. This conflicts with the already saved selected options in the saved params.
for future reference, i changed this:
def _get_gefs(params: Munch, **kwargs) -> List[OptionListElement]:
if not params.user_input.general.use_subset_cpts:
return [OptionListElement(WARNING_MESSAGE)]
gef_options = ['get gef options through api call']
if not gef_options:
return gef_options
in this:
return params.user_input.general.cpts
if not gef_options:
return gef_options
