if params.include_red:
color_options.append('red')
return color_options
class ExampleParametrization(Parametrization):
color = OptionField(‘Pick a color’, options=get_color_options)
include_red = BooleanField(‘Include red’)
When I start the app including the example I get this error. Without the examples the app starts.
C:\Users\bart\viktor-apps\spreadsheet-test>viktor-cli start
A newer version of viktor-cli is available. Use the command ‘viktor-cli upgrade’ to upgrade from v0.13.1 to v0.13.2
2022-03-25 12:35:48.968 INFO : __ __ __ __ __
2022-03-25 12:35:48.969 INFO : \ \ / / | | | |/ /
2022-03-25 12:35:48.970 INFO : \ \ / / | | | ’ /
2022-03-25 12:35:48.970 INFO : \ / / | | | <
2022-03-25 12:35:48.971 INFO : \ / | | | .
2022-03-25 12:35:48.971 INFO : / || ||_
2022-03-25 12:35:48.972 INFO : _______ ____ _____
2022-03-25 12:35:48.972 INFO : |__ | / __ \ | __
2022-03-25 12:35:48.975 INFO : | | | | | | | |) |
2022-03-25 12:35:48.976 INFO : | | | | | | | _ /
2022-03-25 12:35:48.978 INFO : | | | || | | | \
2022-03-25 12:35:48.981 INFO : || _/ |_| _
2022-03-25 12:35:48.983 INFO : VIKTOR connector v5.11.1
2022-03-25 12:35:48.984 INFO : VIKTOR SDK v12.10.0
2022-03-25 12:35:48.997 INFO : Loading SDK…
2022-03-25 12:36:21.734 WARNING : /usr/src/packages/theano/scalar/basic.py:2412: DeprecationWarning: np.bool is a deprecated alias for the builtin bool. To silence this warning, use bool by itself. Doing this will not modify any behavior and is safe. If you specifically wanted the numpy scalar type, use np.bool_ here.
Deprecated in NumPy 1.20; for more details and guidance: NumPy 1.20.0 Release Notes — NumPy v1.23.dev0 Manual
self.ctor = getattr(np, o_type.dtype)
2022-03-25 12:36:26.203 WARNING : Using NumPy C-API based implementation for BLAS functions.
2022-03-25 12:36:31.070 WARNING : /usr/local/lib/python3.7/importlib/_bootstrap.py:219: RuntimeWarning: numpy.ndarray size changed, may indicate binary incompatibility. Expected 16 from C header, got 88 from PyObject
return f(*args, **kwds)
2022-03-25 12:36:33.525 WARNING : /usr/src/packages/theano/tensor/basic.py:369: DeprecationWarning: np.complex is a deprecated alias for the builtin complex. To silence this warning, use complex by itself. Doing this will not modify any behavior and is safe. If you specifically wanted the numpy scalar type, use np.complex128 here.
np.complex(data) # works for all numeric scalars
2022-03-25 12:36:35.205 WARNING : /usr/local/lib/python3.7/multiprocessing/process.py:297: DeprecationWarning: app.calculation_folder.controller.CalculationFolderController: Your app uses an integer type as param value for entity selection fields (ChildEntityOptionField, SiblingEntityOptionField, ChildEntityMultiSelectField, SiblingEntityMultiSelectField), which will change to an Entity type in the future. Please set viktor_convert_entity_field = True and change your code accordingly.
See upgrade instruction U65 for more detail.
self.run()
2022-03-25 12:36:35.220 ERROR : ‘function’ object has no attribute ‘_generate_entity_type’
