This error is probably caused by an incorrect token used by the CLI. Did you configure the CLI to use the new token? This can be done with viktor-cli configure
I have configured it with the token I received by email.
Tried deleting the cli and downloading again a new one from the documentation and reconfiguring.
Placed it in a different directory.
Unfortunately all did not work.
Replace VIKTOR_DEV with the email address, VIKTOR_TOKEN with your token and SUBDOMAIN with the subdomain of your development account. Does this return a 200 status code?
From the check-system it also seems that your system is not yet correctly configured to start using VIKTOR. You need to make sure that Docker desktop is running before you can use VIKTOR. A full set of installation instructions can be found here: Installation | VIKTOR Documentation.
The subdomain does not seem to be correct. This should be the subdomain of your development account dev-amo-mhpoly-nl. Does this still result in a 403?
The value of dev_token should be the token itself, not the name of the file and not the path to the file
Is “amo-token” the actual value you used in the request? This is not correct, it should be the token that is contained in the file you received. This is also holds for supplying the token with the configure command btw.
Can you check if the token you configured is the same as the one you supplied in this command. This can be done with viktor-cli check-system list-accounts. Please do not post the output as it contains the token:)
What I did was to drag and drop the token to the cmd when it asks to supply the token.
Apparently that is not the way.
Instead I have converted it to .txt and copied the token code to cmd and now it works.
